Change entry to sp mode
  • en.
    • Jul 2014
    • 124
    hi there
    have agood day ..
    Is there a way to change the entry to sp mode? I have a set of devices, the model is 5503. I cannot enter sp mode through the code reset 806182. I can only enter factory mode / reset 143 cc
    I heard that there is a program sp mode that changes the entry method and code
    any one can help me
  • davel
    • Oct 2011
    • 1104
    Re: Change entry to sp mode
    Is SP mode access turned off in user tools?
      • 37491
      That would also block access to Factory Mode.
      Originally posted by en.
      hi there
      have agood day ..
      any one can help me
      There is a SP for changing the access code. When Ricoh went to the six digit code instead of the old 3 digit one, some techs decided they did not like having to remember two different code so tries to change the new machines to use the old code only to find that it required a six digit code. They then used the old three digit code twice, ABCABC where ABC is the old three digit code.
