Ricoh PRO C651 - Fusing Belt and Strippper plate
  • reglanet
    • May 2018
    • 36
    Hello, could someone help me by indicating how to calibrate
    the stripper plate and the separation with the fuser band??
    Any tutorial or training video?
    • 37532
    Re: Ricoh PRO C651 - Fusing Belt and Strippper plate
    The stripper plates are factory set and require NO adjustments. If one is damaged, replace the assembly. If they are dirty clean them in accordance with the service manual. unless you are a bench tech in a repair lab rebuilding multiple fusing units a day you should have your service manual open in front of you and follow it step by step. If you don't have a service manual put a request in the service manual request forum.
