IM c3000 copy and scan not registered
  • Marwanalhajbi
    • Jul 2018
    • 72
    I have made a clear memory sp5801-001 ,i inserted all sps of the sp sheet ,however i have an issue with scan and copy, the scanned page is not registered from the top , bottom and the middle, the rest of the page it's registered just fine.
    i tried color calibration for copy and sp 2-111-001 also 2-101001 no result
    please find the attachment WhatsApp Image 2022-03-22 at 11.14.08 AM.jpgWhatsApp Image 2022-03-22 at 11.14.08 AM.jpgWhatsApp Image 2022-03-22 at 11.14.09 AM (2).jpgWhatsApp Image 2022-03-22 at 11.14.09 AM (1).jpg
  • Gift
    • Mar 2011
    • 2457
    Re: IM c3000 copy and scan not registered
    You should avoid a memory clear - if it's about the customer privacy you can just perform SP5804-004->END
    Do you mean the scan image isn't aligned properly on the copy/scan? Then you should tweak these Scanner related SPs:
    4-008-001
    Sub Scan Magnification
    Adj
    ENG* [-1.0 to 1.0 / 0.0 /
    0.1%/step]
    4-010-001
    Sub Scan Registration
    Adj
    ENG* [-2.0 to 2.0 / 0.0 /
    0.1mm/step]
    4-011-001
    Main Scan Reg ENG* [-2.5 to 2.5 / 0.0 /
    0.1mm/step]
    • sandmanmac
      • 3977
      What frustrating samples to provide.
      I, for one, have no idea what those are "supposed" to look like.
      Print off and scan a colour test pattern, and upload a proper PDF.
