Lanier LP116cn SC 530 error code
  • mjwillyone
    Dear Friends,
    I have an error code (SC 530) on a LP116cn color printer. I believe that this printer is the same as the Ricoh Aficio type printers. That is the reason I have posted to this sub group.
    Can anyone tell me 1) What the problem with the machine is 2) what the solution is?
    Thank you so much,
    Mike
  • gstaylor
    • Mar 2009
    • 12
    Mike
    Below from the Ricoh Service manual:
    530 Fusing fan motor error
    The fusing unit fan motor
    does not operate.
    Voltage between pins 2 and 3 (CN9 on engine
    control board) abnormal (not +24V)
    Defective fusing unit fan
    1. Replace the engine control board.
    2. Replace the fusing unit fan.
    Rather than start with replacing the board and fan, I would start by checking the connectors etc.
    Good luck
    Gareth
    _____________________________________________
    Knowledge is knowing a tomato is a fruit.
    Wisdom is knowing not to put it in a fruit salad.
    sigpic
    www.inception.co.uk
    www.inception-store.co.uk
