DESITY ADJUSTMENT RICOH MPC 01, 02, 03 and 04 series
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi All,
    Is there any SP adjustment on density so as to make print job toned just like black and white Ricoh photocopier.
    • 37491
    Re: DESITY ADJUSTMENT RICOH MPC 01, 02, 03 and 04 series
    You could try screwing around with the Developer Gamma settings, but you more likely to make things worse than they current are.
    The proper adjustment in is User Tools - Maintenance - Auto Color calibration. You first have to make sure that all the optics and the ID sensor are clean. Do the Copier Function first. This adjusts the output from the scanner so that the scanned image matches the stored image that was printed. Then all of the Printer Function. This adjusts the printer function processor.
    Don't be surprised to find that there are no previous settings showing, especially with the 03. There was a company internal letter sent out to all branches and dealers that firmware updates might clear the settings.
    • davel
      • Oct 2011
      • 1104
      Use OEM parts and toner, follow PM procedure
        • May 2020
        • 238
        I have done that, just need to play around with the gamma but forgotten it on system sp
          • May 2020
          • 238
          Any system sp for Gamma adjustment? ??
          • copyaction
            • Oct 2007
            • 991
            There was a TSB for the 2003/2503 series suggesting to run SP 3050 forced toner supply, among other things.
            Might be worth a try to see if it is undertoned causing the density problem.
            • Zaxxon
              • 608
              Originally posted by Pixtech Frameworks
              Hi All,
              No.
              Please start you post with brand, model, problem.
