Scan to email question
  • ABS tect
    • Sep 2013
    • 511
    Quick question, are the Ricoh MFP's able to send out scan's FROM multiple email addresses, or only one?
    My understanding is you have the host email address, which you use for all smtp settings and such, and that is the email address that shows up when the email arrives to the destination.
    I know you can register multiple senders, but from my experience it still shows up with the host email address attached with the senders name.
    So are you limited to one, or can you do two.
    I told my customer just to scan to folder and attach it from there and send out with whatever email they would like, but he wanted me to find out if it was possible directly from the copier.
    Thanks, hope i explained that correctly.
    • 37072
    Re: Scan to email question
    Yes. Every entry in the address book can be designated as a sender in addition to be a recipient. That setting can be utilized in 2 ways.
    1. You can require users to login when using the scan function and the address saved for that user will be used.
    2. You can press the "Select Sender" button on the scan to email function screen.
    One thing to consider is that many email providers will reject emails where the sender domain and authentication domain are not the same.
    • ABS tect
      • Sep 2013
      • 511
      Then maybe I am missing something because I knew you could designate all user in the address book as a sender, but it still shows the host email next to the sender name.
      Lets say I have user 1: test@test.com as an example. And my email address I used to setup scan-to-email is abs@abs.com, then when I send a scan to anyone, and say I choose the sender to be user 1, then it always comes through like this.
      Email from : test@test.com <abs@abs.com>
      It always shows the email I used to setup scan to email on the right next to the sender name.
        • 37072
        Most likely because the domains are not the same. test.com and abs.com
        • ABS tect
          • Sep 2013
          • 511
          Then I guess that is the question I should be asking...is it possible to send out from two different domains?
          Because, with my test, even when I select a sender with the same @abs.com as the host email, it still shows the original host email to the right of the sender email address.
          • 8T2
            • Aug 2015
            • 257
            Can't recall ever running into this, usually works just like slim described.
            Maybe try switching off auto sender address for a quick test? But I'm pretty confident that it's a setting on the server side forcing the authentication adress to display if it is the way you describe
            Sending from different domains is also possible if the outgoing SMTP allows it but it usually doesn't anymore these days due to strict security. A couple of years ago loads of my devices were set up using a open public mail server on port 25 with no authentication because it was easier and quicker than getting in touch with their ISP
            Sent from my SM-A305F using Tapatalk
              • 37072
              There is a possibility that it is a function of the email provider. The fact that it does not reject mismatched domains points to this.
              When email destination providers started rejecting domain mismatch emails, Ricoh put out a bulletin about an SP setting that forced the authentication address to only be used for authentication and only the sender to be embedded in the header of the email.
                • 37072
                One additional thing, the address between the <> is there to allow for easier identification of SPAM. One I get on a daily basis is LOWE'S_Shoppers - <elsygrumbling2383@hotmail.com>
                • ABS tect
                  • Sep 2013
                  • 511
                  Ok interesting...
                  Thank you guys, I will do some more testing and playing around, hopefully I can figure it out.
                  Cheers
                  • rthonpm
                    • Aug 2007
                    • 2847
                    It sounds like your email provider has enabled DKIM (Domain Keys Identified Mail), which is a function to help prevent spoofing of mail domains. Since you're trying to send mail from domain A but authenticating with credentials from domain B, the mail server sees that you're trying to spoof an email address and therefore shows the true address that the message is being sent from. I have something similar that happens with my cloud hosted billing system. The emails are configured to show as coming from our regular accounting group email, but the customer sees our email as the sender name, but also the true email address.
                    DKIM is going to be all but standard before long for all mail providers because it easily removes the ability to spoof another email address. Many mail providers will also just add any messages that fail a DKIM test straight to spam. It's the lowest hanging fruit of the spam and malware trees, but as most attacks are quite simple it can be amazingly effective.
                    What's the relationship between the two domains? I know we have a few customers that have multiple domain names, but they are all tied to hosted Exchange through Microsoft 365 and are considered a single unit so that all of the addresses are considered part of the same organisation, even though there is no visible relationship between them. With that, you could have your authentication account(s) with permissions to send from the other domain's email addresses.
                    Sent from my BlackBerry using Tapatalk
                      • 37072
                      I think that one area where a lot of companies get in trouble is when they allow employees to use their own personal email accounts to send emails from the company MFP.
                      • tonerhead
                        • Sep 2009
                        • 582
                        I'm wondering if auto-sender email address needs to be shutdown in user tools. Then you should be able to select sender. Don't know for sure, don't have a machine to play with right now. I've only used default admin email address. Oh I guess this was already suggested.
                        I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                        Especially when it comes to sex
                        • rthonpm
                          • Aug 2007
                          • 2847
                          I've always been in favour of using a dedicated email address for scan to email as it reduces the amount of work required for password maintenance and also gives administrators some degree of control and oversight of what is being sent from the device.
