Ricoh Aficio mp c3300
  • Jeremynzl
    • May 2022
    • 4
    Hi
    I have a new to me Mp3300, Firmware has been updated to latest.
    I am unable getting scan to email to work. I have found conflicting information online as to if this model can do ssl\tls.
    If it does is there a procedure to get this working on smtp2go, or do I need to run a local smtp gateway on my home network.
    My machine has ssl menu options and the option to create cert's which I have had a play around with unsuccessfully. I have tried both gmail and smtp2go with multiple suggested ports.
    I've had no luck with smtp2go on 465 or 2525.
    I've read elsewhere on this forum that 465 may do ssl , But I'am unable to verify what the machine will do
    Does the machine require a hard reboot after each setting change.
    I would be grateful for any advice.
    Thanks Jeremy
    • 37644
    Re: Ricoh Aficio mp c3300
    Originally posted by Jeremynzl
    Hi
    Thanks Jeremy
    The only type of certificate that you can actually create is a self signed device certificate. SMTP over SSL/TLS now requires requires a site certificate issued by a recognized CA, Certificate Authority. Due to the age of the C3300 it may not be able to use a site certificate for email. The documentation I have from Ricoh dated 02/09/2011 only covers the following models. Later model came with site certificate already installed.
    Aficio MP C6501SP, C7501SP
    Aficio MP C4501/A/G/AG, C5501/A/G/AG
    Aficio MP C3001/G, C3501/G
    Aficio MP C300/SR, C400/SR
    Aficio MP C2051, C2551
    Aficio MP C2050, C2550
    • Jeremynzl
      • May 2022
      • 4
      Thankyou for your reply.
      It does help narrowing it down. Worst case I have to build a stunnel relay. Best case I may need to look at purchasing a cert.
        • 37644
        That is not necessary. If a site certificate will work, you can export one from your browser. It is just a matter of which one of the multitude that are on your browser. For the current Firefox version they can be found by clicking on Tools, Settings, Privacy and Security then scroll down to Security, Certificates and click on View Certificates. For the current version of Firefox, one of the GoDaddy.com, Inc. or Google Trust Services LLC might work, possible a Software Security Device. Click on the certificate and you can then Export it to a folder. You can then try importing it to the C3300 using WIM.
        • sandmanmac
          • 3990
          I've never had any success with machines of that generation using email settings that require SSL/TLS.
          However, smtp2go will work on ANY Ricoh machine ever built (and likely any other manufacturer) that has a scan to email option. I use it ALL the time, so you're doing something wrong.
          I have the best luck with port 587.
          • Jeremynzl
            • May 2022
            • 4
            Thankyou Sandman and Slim.
            Ive had another crack with Smtp2go, Cant get it working. Also installed a cert following a Ricoh pdf that was on this site. Still no joy.
            Maybe I should factory reset my machine. and try smtp2go from a clean setup.
            Are either of you able to assist me with factory reset procedure. I have tried the only one I found online which was the 2 numeric keys , which just did a reboot and verification with all user settings still there.
            Cheers Jeremy
              • 37644
              There is always scan to folder, USB or Document Server. I can't remember if that model required the File Format Converter for Document Server files to be download to your PC through WIM.
              For scan to USB or SD Card check the installation procedures for installing USB2.0/SD Slot Type A in the service manual. If your make the SP settings required for the USB2.0/SD Slot Type A, you can then plug USB drive directly into the connector at the back that the adapter would plug into. You can also use a USB extension cable to move the connection to the front of the C3300. Add an SD card to USB adapter and you might be able to use an SD card though I have never tried an SD card. I have use USB drives as described but there may be a size limit. Worked both for scanning to and print from USB drives.
              Once you have the file on a drive of some type you can then use your PC to attach it to an email. Plus you can type more into the body of the email. And if you use an email such as Gmail, the 25MB attachment file size limit is eliminated.
              • rthonpm
                • Aug 2007
                • 2860
                Unless I'm mistaken, the C3300 doesn't support newer versions of TLS, which may be part of the issue.
                STunnel is a good workaround. I have it running on a VM for scan to email and embedded email notifications that get relayed to my M365 tenant.
                Sent from my BlackBerry using Tapatalk
                • Jeremynzl
                  • May 2022
                  • 4
                  After trying all solutions. I ran up a stunnel VM. worked first pop using gmail smtp as configured below through google apps
                  Am still perplexed why smtp2go wont work as I use it on a kyocera we have here so am familiar with its setup.
                  Credit to STunnel - Ubuntu 16.04 - GMail SMTP - CocoonTech.com
                  I used Ubuntu 22.04 live server , static ip in same subnet as printer.
                  Step 2 was missing in in the stunnel4 config so I ignored it, and still worked.
                  Printer settings are static ip of stunnel server for smtp sever and port 5000 , this passes a connection test on the smtp server screen on the Ricoh
                  authentication user and pass are my google apps userass for that acc. Set in the printer
                  I have less secure apps enabled on that acc as its only a relay for the printer
                  I installed it on Ubuntu 16.04 / 64 bit.
                  1 - sudo apt-get install stunnel4
                  2 - nano /etc/default/stunnel4
                  Change: ENABLED=0 to ENABLED=1
                  3 - Configuration
                  create a new stunned configuration file.
                  nano /etc/stunnel/stunnel.conf
                  copy and paste the following to the new file.; ************************************************** ************************
                  ; * Global options *
                  ; Debugging stuff (may be useful for troubleshooting)
                  ; log = overwrite
                  ; foreground = yes
                  debug = 7
                  output = /var/log/stunnel4/stunnel.log
                  ; Certificate/key is needed in server mode and optional in client mode
                  cert = /etc/stunnel/mail.pem
                  ; key = /etc/stunnel/stunnel.pem
                  ; Enable FIPS 140-2 mode if needed for compliance
                  fips = no
                  libwrap=no
                  ; * Service defaults may also be specified in individual service sections *
                  ; Enable support for the insecure SSLv3 protocol
                  options = -NO_SSLv3
                  ; These options provide additional security at some performance degradation
                  options = SINGLE_ECDH_USE
                  options = SINGLE_DH_USE
                  ; * Service definitions (remove all services for inetd mode) *
                  [gmail-smtp]
                  client = yes
                  accept = 5000
                  connect = smtp.gmail.com:465
                  verify = 2
                  CApath = /etc/ssl/certs
                  checkHost = smtp.gmail.com
                  OCSPaia = yes
                  4 - Generate a certificate
                  a - cd /etc/stunnel
                  b - sudo openssl req -new -out mail.pem -keyout mail.pem -nodes -x509 -days 365 *
                  * = press enter for all of the questions. Certificate is good for 365 days
                  5 - Start stop or restart STunnel
                  sudo /etc/init.d/stunnel4 stop
                  sudo /etc/init.d/stunnel4 start
                  sudo /etc/init.d/stunnel4 restart
                  6 - Test it by looking at the stunnel log live
                  tail -f /var/log/stunnel4/stunnel.log
                  7 - Once tested and working change the stunnel.conf file logging options as so
                  ; log = overwrite
                  ; foreground = yes
                  debug = 5
                  debug = LEVEL
                  debugging level
                  Level is a one of the syslog level names or numbers emerg (0), alert (1), crit (2), err (3), warning (4), notice (5), info (6), or debug (7). All logs for the specified level and all levels numerically less than it will be shown. Use debug = debug or debug = 7 for greatest debugging output. The default is notice (5).
                  • rthonpm
                    • Aug 2007
                    • 2860
                    Seeing /etc/init.d makes me feel like I've used a time machine to the past. I've been spoiled by systemd.
                    For a lot of customers, STunnel can be a good option for an internal SMTP relay server. It's lightweight, runs on Linux and Windows, and is easy to configure. I only set it to send as oppose to receive as nothing I use with it needs to receive mail.
                    From my perspective it's also a little more reliable than a service like smtp2go for business customers as it allows them to keep all of their outgoing mail tied to their own mail providers so any additional protection they configured also apply to mail sent through it.
                    • sandmanmac
                      • 3990
                      Well now it's very clear you're quite capable navigating the features and settings on these machines. I wasn't necessarily sure that was the case, and it often ISN'T with many new members / end users (No disrespect intended. It's just the truth).
                      I might suggest that the setting on the machine that is preventing you using SMTP2go could be in User tools. If I remember correctly, it's under System settings / File Transfer / SMTP Authentication.
                      Make sure that "Use secure server" is disabled (since it doesn't support that natively), then try port 2525 or 587.
                      Unlike most newer models this setting is ONLY available via the control panel of the machine and NOT via the WIM.
                      Outside of that, I really don't know what would be the cause.
                      NOTE:
                      As far as performing a factory reset, which would be in SP mode (5801). You do Not want to mess with that, or you will be opening up a can of worms you may never get closed. Just my 2c
                      Good luck
                        • 37644
                        smtp2go has a history of some email providers occasionally not accepting new traffic through them. Google is one of them. It is the result of a bulk mailere sending through smtp2go to mask their real source. When the email provider gets a large number of spam complaints in a short period of time them will block all new traffic through the source they see, smtp2go. Usually lasts no more than a day or two.
                        You also may have been able to send through Google relay server by using your Google workspace Administer login and configuring the relay service for your workspace/domain to accept messages only from a specific public IP address. THat address would the public address of your router and if that ever changes, your have to reconfigure it.
