SNMPv3 Question
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    SNMPv3 Question
    Hey, All,
    Has anyone sucessfully set up SNMPv3 with current model Ricoh machines?
    A customer would like to disable V1 and V2, and just go with 3 in order to tighten down their security.
    I know that a certificate is required on each machine, but can they be the ones that are self-signed device certs, that ship with each machine, or do they need to be actual CA certs?
    I've read where the self-signed should work, but they don't, at least in every instance I've tried to date.
    Thanks!
    • 37532
    How do I configure SNMPv3 on a printer? : sysadmin
    Supported network devices | Cisco, Juniper, Fortinet, HP, Aruba | NCM
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Re: SNMPv3 Question
      Some applications, such as SLNX, and formerly DMNX require SNMP for device management.
      Those same customers frequently run printer vulnerability checks, with some fairly sophisticated network monitoring tools. Right now we are dealing with two banks (for a total of about 600 MFPs, mostly Ricoh), in that very situation.
      SNMP 1 and 2 get dinged as being potentially dangerous, and result in red flags being generated.
      I will check if SLNX would be happy with “read only” capability.
      Thanks!
      • rthonpm
        • Aug 2007
        • 2859
        Re: SNMPv3 Question
        You may need to install the self-signed cert on any devices that are also being used to collect SNMP data. If the device doesn't trust the cert, it may not be able to collect data.
        You may also be able to get away with just changing the SNMP community name to something other than public and also scale down permissions to read only.
        Sent from my BlackBerry using Tapatalk
