is there cmos battery in the copier ricoh?
  • aviso66
    • Dec 2012
    • 202
    hi,
    are there any cmos battery inside the ricoh machine that needs replacement?
    • 37489
    Re: is there cmos battery in the copier ricoh?
    On some Fax boards. Forget to set the jumper and you would get an error message.
    Most of the early NVram had a battery built-in. Current NVram use flash memory or SSD technology.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      If no battery, what maintains the clock when the power is turned off?
      I will rustle up a few manuals next week and check.
        • 37489
        Way back when it was the built-in battery of the CMOS NVram. I had a customer who pulled an old Martini out of storage to use. The battery had died so had to set the clock for them and calibrate the touch screen. They were a time and materials account and did not want to pay for a new NVram. I had to show them how to calibrate the touch screen because every time there was a power outage,it lost the previous setting.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
