MP 5002 Block entry to service mode
  • MIGUELMARCHENA
    • Feb 2018
    • 195
    good day
    we have a client 70 kilometers away, he had an mp3500 and we convinced him to rent a more modern one, for price, he chose the MP 5002,
    As the client reached into his machine and knew how to enter the service mode, he does the same in this rented one, so if he suspects that it will clear up, then he adds and of course, he floods with toner and calls shamelessly.
    I ask
    Is there any way to change or block xxx 107 xxx so that he cannot enter the service mode to play?
    Thanks a lot .
    • 37488
    Re: MP 5002 Block entry to service mode
    Originally posted by MIGUELMARCHENA
    good day
    I ask
    Thanks a lot .
    Multi step process:
    1. Login as supervisor and change the supervisor password to something that only you know.
    2. Create a password for admin2 that only you know
    3. Turn on Service Lock out
    4. Change administrator permissions so that admin still has access to everything the customer needs to access but only Admin2 can disable service lockout
    • MIGUELMARCHENA
      • Feb 2018
      • 195
      Multi step process:
      Hi good day Sorry for the delay in responding, but I've had a lot of work. thank you very much for your idea Greetings.
      • L0rdC
        • Feb 2021
        • 82
        Proceso de varios pasos:
        5. best solution, stop giving service
