Re: C306Z hardware upgrade?
Control Panel.
look! if you want boost your ricoh mf, at zero cost, you can disable the java enviroment from user tools>exension feature>auto start>[deselect java]...this in particular increases the startup speed
for the rest...i suggest that is born like this, dies so...LOL...i think that if ricoh in 2022 use a mechanical hdd, probabily there is a reasonLeave a comment:
I’ve seen machines throw SC errors that were caused by corrupted Java, even when Java wasn’t being used.
As Slim said, disable it if it isn’t needed by an add-on app.
Here’s a tip, though. If Java is on an SD card, simply disable it, and don’t remove the card.
If the card gets removed, it will inevitably get misplaced, and then next thing you know the customer gets an app that requires it. In addition, in most situations, the customer paid extra for the option.
Some models had it included at the factory for some length of time, but those days are gone. In fact, even though the option is still in the price book, it is no longer available for some if not most models (which is an entirely separate sore subject).Leave a comment:
I agree. Unless the customer has a JAVA based app that they absolutely have to use, there is no reason for having JAVA, other than to allow sales personnel to say they have it. On many models you cannot get into SP menus or User Tools other than the Counter until JAVA has finished initializing. On some machines that can be 5 minutes or more.Leave a comment:
for the rest...i suggest that is born unsteady, and dies so...LOL...i think that if ricoh in 2022 use a mechanical hdd, probabily there is a reasonLeave a comment:
After many years, I have the theory that Ricoh mainly uses HDDs as Virtual Memory, instead of using RAM for said processes, being faster. This may be due to how the Operating System (or its kernel) is designed on machines. In fact, it reminds me a lot of how some somewhat older versions of Linux worked, forcing the generation of a specific partition to Virtualize Memory.Leave a comment:
I have a Ricoh c306z, which seems to work but trying to upgrade firmware lately with the Ricoh Upgrade Tool it locks up and I have to power cycle it.
This reminds me of PCs acting up when memory modules are damaged and I wonder if there's a memory test function to confirm the memory module is healthy.
Also, I wonder if changing the module for a bigger one and swapping the hard drive for an SSD would make it any snappier. Any experience in that regard?, are memory and disk upgrades any good?
I don't see the RAM as any potential bottleneck for a MPC306.Leave a comment:
The files that the tools downloads are not SD card firmware. They are either package firmware or remote firmware. Remote firmware files can be installed using WIM.Leave a comment:
533mhz or 1333mhz? If you do the test there is a risk that you will not recognize the RAM by the frequency. And to place one of more capacity, it is unknown what is the maximum that tolerates.
By how they are physically we can intuit that they are DDR2 or DDR3 in some cases, and according to what I look at most are Samsung chip, but the PCB belongs to RICOH itself.
Regarding the subject of testing, if I can tell you that at least in my experience and used RAM modules of copiers / printers in laptops and have worked, it will be a way to make a Memtest (one of the best programs for RAM testing).Leave a comment:
Just wanted to make sure memory module/s are healthy.Leave a comment:
1. Is there a memory test function?
2. Is there a second channel to add another module?
3. If not additional module, would it add any value going with a module bigger than 2GB?Leave a comment:
This remind me of PCs acting up when memory modules are damaged and I wonder if there's a memory test function to confirm the memory modules is healthy.
Also, I wonder if changing the module for a bigger one and swapping the hard drive for an SSD would make it any snappier. Any experience in that regard?, are memory and disk upgrades any good?Leave a comment:
