firmware update
  • antoney suresh das
    • May 2011
    • 103
    firmware update
    Hi Guys,
    I'm having a issue with firmware update via SD card on Ricoh Pro 907ex can some one help/guide
    I've formatted the SD card using a SD card formatter
    I've created a folder "romdata" on the SD card
    I've put all the firmware files into the folder
    Tried to update the machine after a delay shows failed
    where have i gone wrong can some one help.
    thanks
    • 37529
    Re: firmware update
    Originally posted by antoney suresh das
    Hi Guys,
    thanks
    In the romdata folder create a folder named D059 and put all the firmware files in the D059 folder. Also the firmware files that you want to put on the SD card are the extracted .rfu files and not the downloaded rfg*****.zip files.
      • May 2011
      • 103
      Re: firmware update
      thanks slim slob i couldn't get the last part when i unzip using 7zip extractor i get files .fwu files hoe do i convert it to the file format you mentioned?
        • May 2011
        • 103
        Re: firmware update
        i've changed the file extension let me try
          • May 2011
          • 103
          Re: firmware update
          I tried to update initially there was as usual a please wait screen and after a long delay a error code screen popped up showing SC816
          • UNICORNico
            • May 2018
            • 308
            Re: firmware update
            You never ever change the extension of a file. Each format belongs to a specific form of use for the device.
            From where did you download these files and for what specific use? Update by SD or Remotely?
            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
            • davel
              • Oct 2011
              • 1107
              Re: firmware update
              • fbkhan3
                • May 2012
                • 421
                Re: firmware update
                Hi Guys,
                thanks
                Try another card, 2gb or 4 maximum.
                download the .fwu files and extract them.
                Create folder ''Romdata'' create D059 folder in Romdata.
                copy extracted files in D059 folder.
                insert the card in service slot.
                boot the machine probably with door open and follow the instructions on scree,
                Start updating with System/copy first.
                Regard's
                  • May 2011
                  • 103
                  Re: firmware update
                  got the firmware copier firmware uk I guess it is genuine have you any suggestions please
                  • sandmanmac
                    • 3981
                    Re: firmware update
                    Originally posted by davel
                    Shouldn’t they be ‘fwu’ files?
                    X2
                    The files placed in the romdata folder need to be the .fwu extension.
                    You could also try using the Firmware update tool
                    • mikadonovan
                      • May 2008
                      • 2931
                      Re: firmware update
                      FWU files into the romdata folder, insert card into slot 2.
                      NEVER ASSUME ANYTHING
                      • fbkhan3
                        • May 2012
                        • 421
                        Re: firmware update
                        Most of the time Problem is with card. if you haven't done the firmware with this card before try different card, it works well in PC but somehow machine can't read it. you can the post the pic of the file structure on the card here it will be easy to find out if there is something wrong with your file structure.
                        Regard's
                          • 37529
                          Re: firmware update
                          Sorry my mistake. It should be fwu. rfu files are for remote updating through WIM.
                          • UNICORNico
                            • May 2018
                            • 308
                            Re: firmware update
                            Originally posted by sandmanmac
                            X2
                            Los archivos colocados en la carpeta romdata deben ser el . fwu
                            From what has been reported lately in the forum, the application to update the firmware is giving problems.
                            Better the always reliable SD.
                            • DRichard
                              • May 2008
                              • 482
                              Re: firmware update
                              Regard's
                              (My 2 cents...) Unless he has formatted his card with the "approved" formatter tool, he may find the card appears to work fine in a PC and yet it may still not be recognized once inserted into the copier.
                              "Enjoy every sandwich."
                              -- Warren Zevon
