I got a problem with a aficio 700, the customer was complaining it using to much toner it's average copy was 35,000 to 40,000 per bottle, now its doing only 20,000 to 25,000. I have check all the problem connecting to this but still no change. The DV was changed 170,000+ copies ago. Their was a layer of toner all over the drum unit and Dv unit so maybe I think it dumping to much toner in the DV unit so I change the settings still no change.
Any solution for this
