Ricoh mpc3003 pale magenta
  • Gift
    • Mar 2011
    • 2457
    #16
    Re: Ricoh mpc3003 pale magenta
    Originally posted by davel
    So you used some compatible crap developer and used the wrong amount, genuine Ricoh you have to get complete dev unit with the correct amount of dev in it. use of crap parts gives crap prints.
    LOL + that sample looks awful in so many ways -
    • Pixtech Frameworks
      • May 2020
      • 237
      #17
      I didn't used a compatible crap. It came it machine, it was only over gauged. So I had to reduced the developer in the unit. And its my first time working for the customer. It's funny isn't it?
        • 37059
        #18
        If you removed developer from the DVU, then the only solution is to replace the DVU.
          • May 2020
          • 237
          #19
          I only reduced the developer from the developer section.
            • 37059
            #20
            The only "section" that contains developer is the DVU, DeVelopment Unit. It is designed to function with a specific amount of developer. If you remove any developer then it cannot carry enough toner to the drum surface resulting in pale images. Now replace the DVU.
              • May 2020
              • 237
              #21
              I did reduce the Developer from DVU bcos it was causing the pale magenta on one side. I'll go back to client to add up the previous developer so that unit can function well. Thank you.
              • UNICORNico
                • May 2018
                • 308
                #22
                One minute.
                I think I understand, that you took away Developer from the DVU, because it had an excess in one of the extremes? EIN????
                Was that machine or the U. Revealed overturned for some reason? Or was it stored in the wrong position? Phew... I'm seeing very harsh images. for the future of that machine.
                "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
