Problem with CSS cable
  • mikadonovan
    • May 2008
    • 2931
    Hi, All. I have a c307 that is giving me the message "problem with CSS cable". A full PDF search through both the SM and PC looking for "CSS cable" resulted in nothing. Can someone tell me what it is, or what else it is called? Thanks, Mika
    NEVER ASSUME ANYTHING
  • sandmanmac
    • 3981
    Re: Problem with CSS cable
    Hey Mika.
    I think Tonermunkeh has the solution in this thread. I've also posted his reply below. Different model but same solution I imagine.
    Of course Mark Bbb never posted back what his findings were
    mpc3003 "problems with SCC cable"
    Re: mpc3003 "problems with SCC cable"
    Is it SCC or CSS? If it's CSS I've seen this before, it's an SP mode. I'll have a look and see if I can find out what it is.
    Edit -
    5816 1 I/F Setting
    Turns the remote diagnostics off and on.
    [0~2/1]
    0: Remote diagnostics off.
    1: Serial (CSS or NRS) remote diagnostics on.
    2: Network remote diagnostics.
    Set SP5816-001 to off or 2, I think it may be on 1.
    • mikadonovan
      • May 2008
      • 2931
      Originally posted by sandmanmac
      Hey Mika.
      Edit -
      5816 1 I/F Setting
      [0~2/1]
      All right, thanks Sandy! I set it to 0, problem solved.
      • sandmanmac
        • 3981
        Excellent!
        Glad you got it solved, but the real thanks goes to Tonermunkeh.
        I'm just the "copy and paster" on this thread
