Ricoh Mp C2003 sc-144 and front door open sign is on
  • Kiatagi
    • Jun 2018
    • 8
    I have mpc2003 machine that is having sc-144 error and front door open sign is on. I have replaced SIO, SBU,IPU, and bcu but the issue has not yet been resolve. Any idea? Thanks
    • 37480
    Re: Ricoh Mp C2003 sc-144 and front door open sign is on
    Why have you not tried the harness for the 144.
    Door open indication could be a bad door sensor. Try using Input test table to trouble shoot.
    Both problems could be related. Like jams, some SC codes will not clear if the door is not being properly detected as being opened then closed
    • leeyeo
      • 4
      Last week just face this problem due to lightning shock.I change PSU & controller board solve the problem!
      • Kiatagi
        • Jun 2018
        • 8
        hi,
        i have yet to replace the harness. Will try this and will update here. Thanks.
        • Kiatagi
          • Jun 2018
          • 8
          hi, thanks for the input. I will try this also and hopefully can solve the problem. I will update here for the outcome. Thank you.
          • Kiatagi
            • Jun 2018
            • 8
            hi, thanks for this information as I was able to solve the problem today already. I have replaced the PSU only as no stock for controller but luckily machine was able to start up normally and now is working fine already. Appreciate all your replies guys. Thank you.
