trouble to access web base
  • kayjaig
    • 144
    i have trouble to access the web base (XP is used). IP is correct, printing has no problem.
  • Llama God
    • Mar 2009
    • 1353
    Haven't you asked the same question here: http://www.copytechnet.com/forums/ri...se-3035-a.html
    That should help, but log in as supervisor and you can change the administrator passwords.
    • kayjaig
      • 144
      correction for the question.
      thanks llama,
      what i mean for this one is the web page cannot display.
      it shows web page error.
      please advice.
      • Llama God
        • Mar 2009
        • 1353
        Ok, try pinging the device, then unplug it and try pinging it again in case it's a duplicate IP.
        I take it that you can access other webpages from the PC? What is the device plugged into, eg a Cat5 point on the wall, a switch etc...?
        • aabarnes1
          • Mar 2009
          • 620
          web access
          sp 582891 enables web monitor-make sure this is set to 1
          Grant me the serenity to accept the things I cannot change.
          • imaginemoko
            unTrusted Tech
            • Jan 2008
            • 289
            what model are we talking about Sir?
            fix the customer first then fix the machine... its simple and makes life more easy.
            • Jomama46
              • 2900
              Try turning off any firewalls,i.e. Nortons, Macafee, etc.
              sigpic
              A+; Network +; PDI+
              • iMind
                Vacuum Cleaning Expert
                • Mar 2008
                • 1116
                • KopyKat
                  Nurse Ratched of Repair
                  • Nov 2008
                  • 365
                  This may sound odd but I ran up against this with one of my customers just last month. I was trying to do some phone support and he had printed out the config page to get the IP addy. It was something like 192.168.110.050. He was entering it exactly as printed on the config page and could not access the Web interface...it would come up with a search page. WTF?? So I had him enter it as 192.168.110.50 (leaving out that extra '0' before 50) and it worked just fine. Don't ask me why. I have since tried it both ways on different networks and some work either way and some don't.
                  sigpic
                  Relax! This firmware injection won't hurt...but it will take 45 minutes.
                  • Jomama46
                    • 2900
                    I have run into this too, with Win2K and XP. For some reason( and not always) an OS will interpret a 3 digit octet as a hex number instead of binary. WTF?
                    sigpic
                    A+; Network +; PDI+
