how to install a hdd into the Ricoh 1027?
  • neocozhu
    • Mar 2009
    • 72
    1 the hdd must be ide ? is that any volume limited?
    an do anything in the sp mode ? thx!
  • SGT_Snacks-64
    • Oct 2007
    • 157
    Right the HDD is an IDE, but it's a 2.5" Hard Drive (or so I believe) As far as I know there isn't a volume limit but order the HDD from Ricoh and I think they're 20GB. Haven't done one in a while so not sure.
    When you've installed the new Hard Drive it's reccomended you format the HDD in SP Mode (although you don't normally have to, but I would..) You also need to inform the customer that Document server files (and I think Address Book entries) etc will dissappear and have to be reconfigured/rescanned.
    Hope this helps.
    Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
    Asus P5E-VM HDMI
    4GB (2x 2GB) Corsair XMS Xpert II RAM
    ATi Radeon 4870 512MB GFX Card
    2x 74GB WD Raptor Sata HDD (RAID 0)
    500GB Seagate Barracuda Sata II HDD
    500GB Hitachi Sata II HDD
    600W500att OCZ PSU
    -TOTAL HDD SPACE 1148GB-
    • Llama God
      • Mar 2009
      • 1353
      We use non-Ricoh 20gb 2.5" IDE HDDs when we need to replace them, which work fine. We too format them once they're in.
      • neocozhu
        • Mar 2009
        • 72
        thanks u!!!!!!!!!!!!
