SC320 PRO1357EX
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    SC320 PRO1357EX
    Hello everyone, I have a puzzling problem on a PRO1357EX,.
    When trying to print or copy it gets error SC320. I have changed coronas, power pack, developer unit, transfer set,drum, and it still fails.
    Any ideas?
    Thanks in advance.
    Field technician since 1994
  • mikadonovan
    • May 2008
    • 2931
    Re: SC320 PRO1357EX
    There was a problem with the development motor harnesses failing and causing codes, check the TSB's.
    NEVER ASSUME ANYTHING
      • 37513
      Re: SC320 PRO1357EX
      Here is the Bulletin.
      006-rfg043527.pdf
