Not seeing a 2 to 1 feature on a Ricoh MP 4055
  • laser801
    • May 2014
    • 151
    Hello Everyone... One of my customers asked me to show them where the 2 to 1 selection was and when I got there ...To my surprise, There was none... I'm thinking Firmware?? I came back to the office and fired up 4 other units other than a 4055 ( didn't have one) , Similiar year... and there it was "2 to 1"... Firmware??? Or some other means of getting there on the Panel ?? Thanks for any input, Laser 801
  • thebillydangerous
    • Aug 2017
    • 13
    Re: Not seeing a 2 to 1 feature on a Ricoh MP 4055
    Ricoh doesn't put that setting on the copy screen by default, but you can easily add it.
    1-User Tools/Settings
    2-Copier/Document Server Features
    3-Customize Function:Copier
    Then pick a button that is currently on the copier screen but unused, like ID Card Copy or something, and switch it out for 2->1 Copy.
    Cheers, mate.
      • 37532
      It is called Combine. You can combine up to at least 8 pages onto one sheet. Download the User's Guide from Ricoh-usa.com and go to Copying - Combined Copying.
      You must be new to Ricoh because it has been called that for over 20 years.
        • 37532
        Cheers, mate.
        Duplex & Combine is a default button on the Normal Operation Panel and the Classic copy function screen for the SOP.
        • laser801
          • May 2014
          • 151
          Cheers, mate.
          That did it !! Thanks for your help
          • laser801
            • May 2014
            • 151
            They wanted to take a 2 sided original and get 2 single sided copies...I do know what combining is... That selection is there... Thanks! I added the Dbl to single to the Home screen ...
            • laser801
              • May 2014
              • 151
              Thanks Again !!
