sd card for ricoh pro ricoh 1107ex can clone it
  • amir3656
    • Sep 2021
    • 19
    hello every body i need any method for clone printer sd card to another one
    i am a maintenance technician
    I have tried many ways but dont work
    can any one help for that
    thanks
    • 37053
    Re: sd card for ricoh pro ricoh 1107ex can clone it
    Why
    • amir3656
      • Sep 2021
      • 19
      Why
      Because I have alot of machine that needs cards, and I am from Egypt
        • 37053
        Exact what card do you need?
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          thanks
          Clone sd cards never work properly ie: if you clone a post script 3 sd card you will get strange copy quality problem just use original don't waste your time trying
          Regards Mark
          • DRichard
            • May 2008
            • 482
            But...He's from EGYPT!!!
            "Enjoy every sandwich."
            -- Warren Zevon
              • 37053
              Look at the control panel. If it does not have the buttons for Printer and Scanner, then you need a lot more than just the Printer/Scanner SD cards to make them function as a printer. If they do have the buttons but ne SD card then you got screwed.
              One other thing, Ricoh used SD cards that where either 64MB, 128MB or 256MB at the largest possible even as small as 32MB. YOu put too large a card in and the Pro 1107EX won't even recognize and may give an error. And by the way, those smaller cards are exceedingly expensive if saving money is your intention. Not to mention that the stand alone SD card replicators cost thousands of dollars and wont work with cards smaller than 1GB.
              • amir3656
                • Sep 2021
                • 19
                for mp 1100
                and 1107ex i have one of theme card stock one i need to clone it i have alot sd cards empty
                • amir3656
                  • Sep 2021
                  • 19
                  is it working SD card replicators i have alots of cards bro ricoh blue sd cards empty
                    • 37053
                    google it
                    • KeviM
                      • Oct 2019
                      • 324
                      thanks
                      I'm not 100% certain but From my experiences those cards can't be cloned (I may be wrong) . It's because they contain a licence for which you have to pay
                      Check ebay or aliexpress you may find people selling used 1s
                        • 37053
                        And usually a lot less expensive than he'd be able to copy them for. If, like old floppy software disks, it contains a protection finger print, they will not copy.
