Booklet finisher IMC3000
  • GeorgeBest
    • Jul 2009
    • 526
    HI,
    Customer wants to make a presentation using the booklet, fold an staple it
    He uses 160gr paper for the cover, is this possible on the booklet finisher?
    Because in my memory 105gr was the max for folding it
    someone?
    Thanks in advance
  • davidmtupper
    • Jul 2021
    • 326
    Re: Booklet finisher IMC3000
    105 is the max per the user guide.
      • 37544
      If only the cover sheet is 160gsm and you can get 160gsm paper to go through the IMC3000, then the stapling should be no problem. You may need to reduce the number of sheet that can be stapled by 3 or 4 to compensate for the thickness.
