Ricoh Pro C7100X Prinect DFE
  • Don3bdallah
    • Sep 2019
    • 12
    Hello
    I get used ricoh pro c7100X (5th color Station)
    it came with Prinect DFE server
    can anyone help me to connect it to the machine and softwareWhatsApp Image 2022-11-05 at 15.20.08.jpg
    • 37054
    Re: Ricoh Pro C7100X Prinect DFE
    Most likely very similar to connecting a Fiery since Heidelberg Prinect integrates with EFI to provide digital printing as Heidelberg Prinect DFE is mainly Digital Front End control system for offset presses. EFI - Heidelberg Prinect Integration - Overview
    • kevslane
      • Mar 2017
      • 24
      Unless you are going to put the printer into a heildelberg account I wouldn't bother trying to connect it as it's very different to a Fiery and you have limited options as it's designed as an output rip after all the settings have been set in the heildelberg colour flow software.
      Sent from my SM-A526B using Tapatalk
      • Don3bdallah
        • Sep 2019
        • 12
        so what i should i do to make it work?
          • 37054
          Forget about the Prinet DFE controller and activate the internal GW controller.
          • kevslane
            • Mar 2017
            • 24
            Or find a Fiery for it.
            • bat
              • Sep 2008
              • 138
              Prinect DFE is different from Fiery server, a wile a go I tried to connect Prinect to pro C7100 and with all my efforts, I did not succeed, what I found out and most importantly, the Prinect server works through an account with Heilderberg...good luck
              • bojans
                • 1313
                Hello
                can anyone help me to connect it to the machine and software[ATTACH=CONFIG]55295[/ATTACH]
                You have provided too little info, and Im not sure what you're asking for.
                Did you connect Prinect DFE and Ricoh machine with crossover cable? What do you see on Ricoh display and on the monitor connected to Prinect when you power on both devices?
                You must be sure that you have stand alone prinect system with proper licence.
                If you dont have stand alone system with permanent licence , getting that would cost more than you paid for machine.
