Hello everyone
How can i use the tray parameters in a Ricoh imc3500 by the webinterface in the printer settings
Has somewone a list of those parameters for a copier with 4 trays and a bypass en a LCT
Tray parameter replacement is useful if, for example, your company decided to replace printers used in the ERP system with another manufacturer's printers. If Company A printers (tray parameter "4" is recognized as "Tray 1") are replaced by Company B printers (tray parameter "4" is recognized as "Tray 3"), the former parameter assignments are retained, so print jobs sent to Tray 1 are output through Tray 3. To restore the correct print path without changing the ERP system settings, parameter "4" assignment must be changed from Tray 3 to Tray 1
thanks
thanks
