Sc code 559 on ricoh proc5300
  • hf.3h2a
    • Dec 2011
    • 2
    [Error Code] Sc code 559 on ricoh proc5300
    Hi all
    same body have information to resolve the sc code 559
    thinks
    • 37628
    Re: Sc code 559 on ricoh proc5300
    It is an error caused by repeated, 3 consecutive, fusing late jams.
    Fusing jam (fusing exit sensor late jam) was detected 3 times
    consecutively.
    Details:
    This SC can be set ON/OFF. The factory setting is OFF; set it
    ON when requested by the customer.
    SP1-142-001:
    0: OFF (factory setting)
    1: ON (set by service personnel at the request of customer)
    This prevents collateral problems (such as thermistor floating)
    that may be caused by repeated jams in the fusing unit
    If you do not have a service manual, put a request in the Service Manual Request forum.
