richo fax 3310 le
  • copierlady
    • 338
    richo fax 3310 le
    WORKING ON A RICHO FAX AND GETTING A 05448 CALL FOR SERVICE CODE. I THINK IT IS A FUSER CODE BECAUSE A FORGOT THE GROUND WIRE BUT NOW I NEED TO GET INTO SERVICE MODE TO RESET IT CAN ANYONE HELP ME? I MOSTLY WORK ON KONICA MINOLTA COPIERS. BUT WITH THE ECONOMY THE WAY IT IS I HAVE TO WORK ON EVERYTHING!!! THANKS
  • CorkyShark
    • 51
    Ricoh fax 3310 le
    Service code 548 means fusing temp is high. Could be a TRIAC short or fan is not running.
