Pro C5210s Cyan DV Unit
  • tufbnme
    • 493
    Looking for a good used DV unit or if someone can tell me if the 5100 or 8002 is the same. I know the part numbers are different but are the units interchangeable?
    • 37059
    Re: Pro C5210s Cyan DV Unit
    No. Different toner,developer,drum and most PM parts.
    • tufbnme
      • 493
      Thanks but I should have read my post. I meant a 8003 not 02.
      Anything cross over there?
        • 37059
        According to Precision Roller, the developer is the same but not the toner. That tells me that there most be something physically different other than 2K larger yield and a $90.00 higher price.
        SP C8003 toner is the same as that for the IM C8003
        • tufbnme
          • 493
          Here's an update, found a wrecked MPC8003, tried the cyan PCDU and it works in the 5210, they are identical.
