MP6500 sc590
MP6500 sc590
This call came in again for my attention this afternoon. I can tell you on the last visit the whole toner recycling system was cleaned out and all motors/tubes/augers and belts observed and were working correctly. All sensors cleaned and the latest appropriate firmware on the machine. There is no strain on any of the motors or gears and the toner recycling motor has been swapped with a good one. And no the toner bottle is not full! Any clues out there
Grant me the serenity to accept the things I cannot change. -
Was the toner system clogged on your last visit? Perhaps you have a coil that is damaged and clogging the system again?
Cleaning the sensors in the recycle unit doesn't always do the trick...you may have one that is bad. I had a few.
If the engine firmware is 1.08 or above, the sensors are good, no problems with the coils and you're sure there is are no drive problems the next step unfortunately is the BCU.
I would re-seat all the connectors on the BCU first. Had more than one instance where this has fixed a multitude of problems.sigpic
Relax! This firmware injection won't hurt...but it will take 45 minutes.
Remove rear covers - look up into the area where the thin drive belt drives the cam that runs the recylce tube from the transfer assy - there is a photo-sensor that monitors the rotation of the cam - I have found that this sensor becomes dirty causing the machine to falsely detect that the cam is not turning when actually it is - the machine codes being that it detects the cam is stationary as if the system is blocked up. This sensor is extremely difficult to see - you need to look from the floor up to see it -once you locate the cam (about size of half-dollar coin) you'll see the sensor located beneath it - using canned air blow out the sensor - if you are not familiar with cleaning this sensor it will be difficult to see at first - once the sensor is cleared of dust and dirt the problem should clear.
CavemanComment
sc590
Thanx lads, Caveman you were nearly right. As I had said all motors,tubes,sensors etc were clean including the 1 you highlighted, (I'M actually very familiar with that particular sensor as we have a lot of these sc's due to damp weather). The problem was actually a combination of a dry joint on the sensor pcb and the brass bushing that sits behind the half dollar wheel you mentioned was seized up with hard toner. Replaced sensor and cleaned bushing- working like a dreamGrant me the serenity to accept the things I cannot change.Comment
Check section 6.8.10 in the service manual.
First diagram, Item D.
Remove the coil from the unit and check the weld between the coil and the shaft.
I went to a Tech call which was throwing up sc 590 and the weld was broken, causing a similar problem.
Hope this helpsComment
possible confusion sc590 for sc495 in manual ?
According to my experience sc590 comes instead sc495 because dirty sensor F.
Its easy to check it - try unplug sensor E and print - SC495 is comming immediately. I spent ages before I found it. All pipes cleaned, drive OK, gears, coils etc.
All the best
P.Comment
All the best
P.
Strip out the unit behind the WTB abd check the auger! If broken it will cause the code to return when the transfer auger backs up. This fooled us for some time (see my previous post) and kept coming back every week after cleaning the recycling.Comment
I reported that when I replaced the sensor and cleaned out the brass bushing behind the half dollar wheel the machine worked fine -and still is. It's a very high volume machine and we haven't been back to it since. I am however going back to an sc124 on a 551 any views on thisGrant me the serenity to accept the things I cannot change.Comment
Re your ADF551 problem, Check out RTBs 9b and 26 on RUK TESSA (See excerpts attached).
This machine suffered from scanner crashing due to faulty MCU boards and DCPSU.Comment
...... attached (!)Attached FilesComment
Thanks for that, I saw that rtb. One thing I did notice with the machine was how much it moved when copying and scanning simultaneously. As it's on that industrial carpet stuff I decided to apply the stabilizers to restrict movement. I stayed with the customer for an hour while approx 350 scans were made and no sc124. If it comes in again I'll have to go with the rtb. However trying to convince our service manager to buy a board on the stregnth of a Ricoh rtb is a challenge I wouldn't wish on my worst enemy!!Grant me the serenity to accept the things I cannot change.Comment
You should at least check the scanner pulley set screw. It is easy to check, and is a very common problem on that model. If it is loose or broken you will get excessive movement (slamming of the scanner).Don't take that toner with me!Comment
Hell of a choice!
Wrath of the Manager, or re stringing The scanner on an AF551!!!
Ist thing to do is check the serial number against the cut off on the RTBs
2nd, invest in the modified (Hardened) scanner screws, less likely to shear.
3rd, check the internal cover to the right hand side of the lens block cover for signs of damage, will indicate if the scanner has crashed at all.Comment
