Ricoh Aficio 2035e
  • TecnocopyVI
    • 45
    Ricoh Aficio 2035e
    Hello,
    I have a problem with Ricoh Aficio 2035e, when i start a copy (from all the drawers) the sheets to half are folded,every copy!!!
    someone can help me?!
    thanks al lot .
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Is the image over the fold or under the fold?
    If it's over the fold it sounds like a clutch issue. Check and replaced the timing and transport clutches. If it's under the fold, check the fuser, entrance plate and finisher/transport.
    • bonnie750
      • 302
      I'd go for regi clutch if its all trays
      • schooltech
        School District Tech
        • Jun 2008
        • 504
        x 2
        Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
        • dckm
          • 79
          Actually, I would replace the transport clutch before the reg clutch.
          • bonnie750
            • 302
            relay clutch? usually not a problem on this m/c but a possibility certainly
            • Rorschach
              • Nov 2008
              • 64
              Second this. I've had to do the relay clutch on several 2035s now, due to folding.
              Today's subliminal quote is:
              • paulg
                • Jun 2007
                • 278
                If your boss allows change the reg and relay as a set unless very low copy count on the machine. Its worth changing both otherwise often the other will go shortly after and while you have the back off etc.
                Also if one tray is used for 80-90 percent of all copies its worth checking the paper feed one as well.
                Quite often a simply 5804 on/off check will help you check if the clutchs are working. Switching on and off in rapid succession if you hear nothing or only one or two clicks and then nothing investigate further.
                • robikan africa
                  • Sep 2008
                  • 38
                  i had the same problem with a client machine..en the reg clutch was da problem..tho tru i found out later that i had to replace the relay clutch...
