MP4000 With 3 fax lines
  • stig
    OVERWORKED..UNDERPAID
    • 52
    Hello today I installed a mp4000 with 3 fax lines installed as specified by the customer. On arrival they asked if each fax line could be set up to receive faxes from different paper trays as different coloured paper would be used for each line. finisher and 2 lower trays installed also. system settings only shows up 1 tray for fax, 1 for print and 1 for copy. Can this be done? thanks in advance.
  • rthonpm
    • Aug 2007
    • 2854
    This is just a guess, but since by the logic of the machine, even though there are three lines coming in they are all controlled by one board I would say no.
    Since the machine only sees one fax function all of the features are going to draw from a single location.
    • Kopyrtek
      Copier Psychologist
      • Jan 2007
      • 407
      Have to agree with rthonpm...only one way to deviate faxes to one tray.No way to tell one fax from another.
      • limo
        • Jun 2008
        • 103
        Only way you can do that is to program special senders.
        Unfortunately you can program only 30 numbers.
