SC320 on Ricoh aficio 1035
  • Edutech
    • 16
    I checked all the laser unit connections and they seemed OK. I even wiped the mirrors inside the laser units but still couldn't get rid of the problem. Any ideas?
    "Everything is okay in the end, if it's not ok, then it's not the end."
  • mikadonovan
    • May 2008
    • 2931
    The polygon mirror motor has failed.
    P/N AX060142
    NEVER ASSUME ANYTHING
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      P/N AX060142
      x2.
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        Originally posted by cobiray
        x2.
        x3 plus replace the micro switches...
        fix the customer first then fix the machine... its simple and makes life more easy.
        • Edutech
          • 16
          Thanks a bunch
          P/N AX060142
          I will replace and then give you the feedback. Thanks for your help guys.
          • cosmic18
            • 19
            Reset laser beam pitch for both 400/600 this will sort the problem out
            • ccchuah
              • Mar 2009
              • 158
              Laser beam pitch adjustment is for service code 322/326 only. for sc320, you will need to replace the polygon motor.
              • stephend
                Senior Technician
                • 306
                SC 320
                SC 320 : Polygon motor error
                The polygon motor does not reach its
                operating speed within 25 seconds
                after the polygon motor on signal, or
                the lock signal is still activated for
                more than 2 seconds after the
                polygon motor off signal.
                I/F harness at the polygon drive motor
                disconnected or defective
                Polygon motor or polygon motor driver
                defective
                Polygon motor drive pulse not output
                correctly
                LOCK signal could not be detected
                Rplc the poly motor and your problem is fixed.
                • Edutech
                  • 16
                  Sc320 on Aficio 1035
                  I did replace the polygon motor and i am a one happy man. It did solve the problem perfectly. Thanks for you help and concern guys. Its really appreciated.
