pro c751 printer features is gone
  • vargue
    • Oct 2011
    • 404
    [Misc] pro c751 printer features is gone
    hello fellas
    first of all i bought printer proc751 and converted to photocopier proc751 and begin to swap scanner chassis and pcb's from proc651 and every looks great and turned on machine every thing run like a shamp .all features working perfect after a few 2 month's .customer come to received machine and suddenly printer features disappeared.scanner features only appeared .i replaced fiery network cable and two LAN card in controller, get 3 fiery CPU one of them suddenly show printer features after 10 seconds disappeared again.i have headache.after while i replaced controller same issue appeared and suddenly after 10 seconds it's gone .any clue please
    • 37556
    Re: pro c751 printer features is gone
    Your problem might be in trying to change the model of a the main frame. In order to make a M044 Pro C751 printer into a D075EX MFP you need to have a valid serial number for a C751EX. Was there a problem with C651EX? Other than being a toner belching beast.
    • vargue
      • Oct 2011
      • 404
      May be firmware issue 🤔🤔 need update
