Size wize counter report on Ricoh.
  • nadimtopsecret
    Experienced Tech
    • Mar 2013
    • 47
    One of our clients wants to print in A5 and also view the counter in page size wise. Currently I checked when I print something in A5 page it increases 1 page in total counter but it's not showing if it's an A5 page or not. How to find page size wise counter from machine. Machine Model Ricoh MP 3054SP.
  • L0rdC
    • Feb 2021
    • 82
    Re: Size wize counter report on Ricoh.
    Web browser or in service mode, sp-8441002 A4, sp-8441003 A5
    • nadimtopsecret
      Experienced Tech
      • Mar 2013
      • 47
      Thanks, I found it. But customer wants it as a report like in counter copy. Is there any option for that ? Cause, here I can view that only.
      • L0rdC
        • Feb 2021
        • 82
        I don't know of any way to print the counter by size on that machine, the only thing that occurs to me, if the counters appear on the web portal, print the page
        • nadimtopsecret
          Experienced Tech
          • Mar 2013
          • 47
          Also not seeing in the web portal.
            • 37488
            There are a couple of additional counter printing options if User Tools / System Settings / Administrative Settings. The two that I have used give you counts by each user and the other breaks the counts down by each function as well as a separate document feeder count. If not there you may have to see if there is an app or maybe contact Ricoh to have one written. The numbers are already stored for SP 8441 to be able to show them. It is merely a matter of an app to read those and display/print those register values.
