Went to the client and changed the drum and blade because was streaking. Removed the charge roller and cleaned it. Machine has around 150k on it.
The problem is when I put the unit back together I get a gray background. There is no print at all- just a gray background. I have tried to re-assemble the unit, checked the contacts etc. Also am getting a SC350 code ID sensor?
