@remote
  • drwevil
    • Nov 2013
    • 53
    @remote
  • kevslane
    • Mar 2017
    • 24
    Re: @remote
    @remote is still active and in use, not being retired at all.
    Sent from my SM-A526B using Tapatalk
    • drwevil
      • Nov 2013
      • 53
      Re: @remote
      • kevslane
        • Mar 2017
        • 24
        Re: @remote
        The encryption level on the server is being updated from 512bit to 2048bit, you can check sp5-816-087 for the level, 1=512 2=2048.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          Re: @remote
          All machines will use 2048 bit if they are able to.
          Only machines older than 11A are stuck with 512, and new firmware will not change that.
          I do know that there is an SP to force 512, but it's set for 2048 by default.
          • drwevil
            • Nov 2013
            • 53
            Re: @remote
            Are the @remote appliances still used for the bigger clients and if do how many machines can they handle?
            it used to be 100 per @remote appliance, if o remember correctly.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3945
              Re: @remote
              It depends on whether the MFPs are in monitored or managed mode.
              The number are actually much higher than that, I just don't remember them offhand.
              Most customers who are using it are running Streamline with the @Remote Connector option.
              The connector does not require a hardware gateway; it's all software. We see very few of the hardware gateways these days.
              Streamline is available in a "Base Only" version, which does not control scanning and printing, so it therefore is much less expensive.,
                • 36584
                Re: @remote
                From the service manual for one of the early appliances, the RC Gate BN1:
                Maximum number of devices to be connected
                • Internet encryption communication (HTTPS) Method
                • Controlled devices registered to the Communication Server 100 devices (including a maximum of 5 devices connected to the RS-485 interface)
                • Auto Discovery: 500 devices (including those registered to the Communication Server on the Network)
                • E-mail (SMTP) Method`
                • Auto Discovery 500 devices
                Appliances are used to reduce the bandwidth usage on the customer's network and internet connection. If I remember from when I took the online training, there was a table showing when you needed to use appliances. I think that it was for any network with more than 5 registered devices. It might also be possible to cascade appliances.
                • Ricoh-ono
                  • 339
                  Re: @remote
                  @Remote is still going strong. Hardware appliances are the only thing being phased out. Embedded @Remote and "Software Appliances" will be supported going forward.
                  Do what you can, with what you have, where you are. ~Theodore Roosevelt
                  • Ricoh-ono
                    • 339
                    Re: @remote
                    I think the newer models are SP5816-102.
