Mpcw2201- paper not cutting once it match.
  • manoj.k.nair
    • Sep 2012
    • 50
    [Jamming] Mpcw2201- paper not cutting once it match.
    HI.
    Good evening.
    PROBLEM : Paper not gets cut after matching. mpcw2201.It is role bak and says paper empty.
    If you off the Auto paer selection its cuts and possible print cointer sheet. single feeder only.
    There is no jam singe .
    Replaced parts:
    Encoder strips.
    Dress sensor.
    Upgrade with latest firmware.
    Clean all the sensor feed unit ext path.
    If any body known this issue.please update.
    M N AIR
    • 37375
    Re: Mpcw2201- paper not cutting once it match.
    Check all connections to the roll feeder. Check that the roll of paper is properly mounted on the roll holder and that the holder is properly placed in the drawer.
    • manoj.k.nair
      • Sep 2012
      • 50
      Hello.
      Hi.
      Paper feed feeding and matching normaly . But not cutting. Head will moove left to right and after that cutter is not mooving and then paper roleback.
      strange?
      i wish to uplode video?.How i can uplode video?
      M N AIR
        • 37375
        Originally posted by manoj.k.nair
        Hello.
        Hi.
        strange?
        YouTube videos can be pasted as link. Same with most social media videos such as Facebook and Twitter.
        YouTube is the best bet unless you are familiar to creating videos on other platforms. Just click on the camera icon at the top right and select upload.
        • manoj.k.nair
          • Sep 2012
          • 50
          Hi.
          kindly check the link.
          3 July 2023 - YouTube.
          M N AIR
            • 37375
            Looks like it is not able to properly identify the lead edge of the paper in order to start printing.
            • manoj.k.nair
              • Sep 2012
              • 50
              Hi.
              If it is like that,if i turned off the auto paper selection i am able to pring the counter sheet.
              i upgrade with latest firmware as well.
              Any way thank you for your support and your time.
              M N AIR
