MPC 2050 Error SC995-1
  • orcast2000
    • Jun 2025
    Error SC 995-1.
    I have had to replace the Frams and the Eprom, I have not been able to make the Backup.
    How can I insert the serial number?
  • stephend
    Senior Technician
    • 306
    As far as I remember you should check SP5811. You must be in Special service mode.
    • orcast2000
      Fact, has tried already to enter Factory Mode and to insert the SNs in the bicu and in the fram but later to the reboot of it always gives the same error.
      • tcs04
        FORMER Techie
        • 1183
        Try checking / setting SP5907-01 "Plug and play Maker / Model Name" (in factory mode?) I seem to remember having trouble entering a serial number on an older machine when this was not entered first. Read the manual for correct setting method.
        • imaginemoko
          unTrusted Tech
          • Jan 2008
          • 289
          sp 5811 to enter the serial number....
          fix the customer first then fix the machine... its simple and makes life more easy.
          • tcs04
            FORMER Techie
            • 1183
            He has tried this!!!
            But if the machine does not know where or what it is it may not let you enter the serial number!!!
            SP 5811 assumes you have saved the NVRAM to SD card and the uploaded onto the new NVRAM (?) before entering the serial number, but if you can't do this because the NVRAM is crashed?????
            • orcast2000
              Following the sudden breakdown of the NVRAM you/he/she has been impossible to make the Backup on SD, as I have described above, after the substitution I have had to manually insert the values of the defaults value and later to insert the SN with 5811 from SP.
              • orcast2000
                From SP mode you can be inserted only a SN, if you enters SP mode Factory, (c) 143 < c > 2" < c >, the SNs can be inserted in the BICU and in the FRAM.
                Everything this has been useless because, as I have already described, continuous to give me error SC995-1 to the reboot.
                Best regards.
                P.S. The formality SP Factory is known at little technicians, only from the technicians of the mother house, I have made an indiscretion to reveal it. ;-)))
                • tcs04
                  FORMER Techie
                  • 1183
                  I repeat
                  "Try checking / setting SP5907-01 "Plug and play Maker / Model Name" in factory mode," with the front door open?
                  Tell the machine where you are!!!
                  BEFORE SP5811
