Ricoh MP7000
  • toshiba
    • Dec 2006
    • 58
    Ricoh MP7000
    Hi friends,
    What can be done to solve intermittent SC551 in MP7000? Thermistors replaced, Engine firmware updated. Error get reset in SP mode reset, but repeats after 2,3 days. Only 100k copies done so far.
  • Eric1968
    • 2458
    Does the thermistor make good contact with the hot roller? Hot Roller dirty?
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      Check the wall voltage for steady voltage. Check the hot roller for a flat spot also. You also might want to replace the thermal switches. We like to replace all three with the high temp unit (AW110066).
