RICOH wide format MPW 6700sp problem with scanner
  • Andy74
    • Feb 2021
    • 25
    Hi, I have a problem with the scanner and copying in this model.Machine prints well but black stripes appear when scanning and copying .Picture attached.Anyone had a similar problem?Thanks for info on how to fix it.
    • 37628
    Re: RICOH wide format MPW 6700sp problem with scanner
    If you are really you have some major contamination of the CIS, Contact Image Sensor, glass that can be cleaned off. If not, you're looking at having the CIS replaced.
    • Andy74
      • Feb 2021
      • 25
      thanks It is this part number D0CW1780 ?
      /5 pcs led lamp/
      What glass should I clean ?
