Ricoh Aficio MP W2400 scan to email
  • junior34pl
    • Aug 2023
    • 2
    Hello,
    I'm trying to set up scan to email on a Ricoh Aficio MP W240 wide format printer, but it won't work. The email service that I use is Gmail. We have 20+ Ricoh printers (newer models) that use the same SMTP settings and can connect to email without any problem. Some people said that the printer might need a firmware update. Is there a way to download a firmware without being an authorized Ricoh technician?
  • ridgemill
    • Sep 2017
    • 190
    Re: Ricoh Aficio MP W2400 scan to email
    The latest FW for this model was released in 2010, so very unlikely it will make much of a difference.
    If you have 2-factor on Gmail it should work, if you generate an App password. You may have to use port 587 (StartTLS).
    • rthonpm
      • Aug 2007
      • 2854
      The TLS versions on that machine are probably too weak. You'll need to set up a relay server, like Stunnel to give the messages modern encryption.
      Sent from my Pixel 6 Pro using Tapatalk
        • 37491
        I am assuming that you are wanting to use the W2400 send wide documents. Even using a relay, you mat still have problems with multi-page wide documents like construction project sets if the scanned size exceeds 25MB. In those cases you will need to scan to a folder and and send using gmail. Gmail uploads the oversize file to your Google drive and attach a link to the email.
          • 37491
          I believe it may be too old to support StartTLS. If your gmail is a corporate account instead of a personal one, your IT should be able as Work Space Administrator to set up proper access.
          Send email from a printer, scanner, or app - Google Workspace Admin Help
          • junior34pl
            • Aug 2023
            • 2
            Scan to folder won't work in this case. I believe this machine is using SMB 1 and SMB 1 on the server is disabled.
