aficio cl 7000
  • DINGO
    • 661
    aficio cl 7000
  • df3036
    • 109
    You may try changing Ethernet speed to 10Mb or 100Mb instead of Auto.
    Kittens give Morbo gas.
    A+, Network+, Server+, PDI+
    • DINGO
      • 661
      re
      HY, thanks
      hwo y change it??
      • df3036
        • 109
        On the MFP go to User Tools -> System -> Interface and it should be there. On the Printer press Menu-> Host Interface-> Ethernet I believe.
        • DINGO
          • 661
          re
          thanks, y go to try.
          • DINGO
            • 661
            re
            Hy
            Y m again.
            Y try that, but is the same. Someone tel me that is because the copier have the hard disk.
            (but is a big diference, like that 5x more to print)
            thanks
            • Jomama46
              • 2900
              Are they both using the same print server? Often, if you dont have a lot of users, printing directly instead of using a server is faster.
              sigpic
              A+; Network +; PDI+
              • DINGO
                • 661
                re
                Ok
                the two prints are conect to network by a wireless router that have 4 10/100 ports., and y just have try change the port, and is the same.
                thanks anyway.
                • buttalasso
                  Maybe it is a stupid idea, but you can try to change the ethernet cable
                  or change the ip address of the driver of the cl7000 that works fine with the ip of the printer that doesn't work fine.
                  It could be a problem of the hard disk, can you hear a bad rumor when you turn on the machine?
                  • DINGO
                    • 661
                    re
                    hy
                    yes , y just have do everything that you sugest, and the hard disk its good.
                    So y change the print/drive pcl5, by the ricoh print driver and stay better.
                    its now acceptable.
                    thanks my friend
