I've got an older Savin C3333 (Ricoh MPC3300) that can't scan to folder. I've done all the usual things.
user for copier is set up as admin (local user)
Folder shared properly
SMB enabled in windows settings
File and Print sharing set up correctly (I think)
File and printer sharing in defender enabled for ALL options both in and out
Turned off Malware bytes to test
Error in log is "SMBC: failed to connect (03201:0x2100002"
I have gone through about everything I know to make this work. Is there anyone out there still using these older machines that make them work reliably?
Thanks!
Jim Tanis NX0R
Thanks!
Jim Tanis NX0R
