SC202 MPC1500sp
  • aabarnes1
    • Mar 2009
    • 620
    SC202 MPC1500sp
    We only have one of these in the field and it keeps giving up this code. My first visit today, so I followed the service manual and cleaned the whole shabang. Worked fine for about 15 colour prints and then sc202. Cleaned again and reset the air counters in sp7215. Has anyone out there had similar, any advice or will I just change the maintenance module.Machine is working ok at present but I fear for it!!!!
    Grant me the serenity to accept the things I cannot change.
  • RebelPhoenix
    • Oct 2008
    • 138
    Hi dear aabarnes,
    I have this machine and I don't live this trouble. I make a research for your trouble.
    Tank full level error: Tank full sensor defective
    Tank Full Lever sensor: Check SP 7215- if highest value 10x the lowest value replace engine
    Tank Full Lever sensor: Defective Tank full sensor sensor/harness
    Tank Full Lever sensor: Dirty/Defective main scan encoder sensor
    Tank Full Lever sensor: Incorrect position of print head carriage slider- see TSB#13
    Tank Full Lever sensor: Replace engine
    Tank Full Sensor - reset using SP2505
    Tank Full Sensor - reset using SP7804
    And Ricoh create a technical bulletion for this problem I atteched this bulletin on topic.
    Best regards
    • aabarnes1
      • Mar 2009
      • 620
      Just to post back on this, I replaced the maintenance unit and the machine is flying
      • Jomama46
        • 2900
        Good news
        sigpic
        A+; Network +; PDI+
        • RebelPhoenix
          • Oct 2008
          • 138
          Ok dear, I'm very blush. I didn't be careful
