Fax memory question(s)
  • Old Crow
    • Aug 2011
    • 203
    Anyone know where I can get Ricoh fax memory unit Type 12? EDP code MX417102RA, Product code D3A510. I've tried the usual vendors, ebay, Google, etc. but no luck. Is it necessary to use proprietary memory? I'm guessing it probably is...thanks.
    • 37572
    Re: Fax memory question(s)
    It's not proprietary. you just need to know the type and speed. Do you have the Fax Unit parts catalog? If so the information should be in it or if you have another machine with it installed, the manufacturer's label should provide all the information. The biggest problem will be finding anyone that has memory as small as 64MB. Most are in the GB size.
    • Old Crow
      • Aug 2011
      • 203
      Thanks slimslob, I'll have to check. I have the machine service and parts manuals (MP4054), don't know if the fax is included, probably an accessory. Yeah 64MB is pretty small nowadays.
      • Old Crow
        • Aug 2011
        • 203
        Update: Still no luck finding this fax memory. I've spoken to a couple of authorized dealers and no luck, the EDP code MX417102RA comes back discontinued. Can't find anyone on the web that has it.
        I've tried a couple of non Ricoh dimm's, 72 pin/64mb, but they are not recognized. I scoured both the parts manual and service manual but didn't find any useful info. I've never seen a fax board with an extra memory dimm...I guess it's just not a common need.
        If anyone out there has this, I'm a willing buyer!
          • 37572
          That could be because of being the wrong size. It may require 32MB. If you can tell us the model FAX, I can check manuals to see exactly what it needs. FYI, Ricoh does not make memory.They off the shelf from memory manufacturers. What their engineers do is write the specs as to what is recognized.
          • Old Crow
            • Aug 2011
            • 203
            It's on a MP 4054. The fax info is:
            Fax Option Type M12
            EDP Code 417100
            Product Code D3A501
              • 37572
              D3A55192 PCB:SDRAM-DIMM:64MB:PC100. If it is not PC100, it might not work.
              Parts catalog Fax Option Type M12, G3 Interface Unit Type M12.pdf
              Service manual is too large to upload. PM me if you want it.
              • Old Crow
                • Aug 2011
                • 203
                Slimslob, thanks for this information and the lesson on memory dimms. The ones that I tried were in fact not PC100. I will try again to find one that is and see if that works. Will let know what happens.
