aficio 1075
  • tecnoacre
    • May 2009
    • 29
    aficio 1075
    tenho uma copiadora 1075 que derramou revelador em cima da unit feed, ja troquei as engrenagem da unit feed mais continua a misfeeds.
  • Eric1968
    • 2458
    Try posting in English, I'll bett you get a better response.
    • fshead
      • 2376
      Portuguese........It looks like the flag of BRAZIL..
      • Fearless V K
        • 620
        You will probably need to disassemble the feed unit completely to clean the developer from all of the one way bearings and roller shaft bushings. Do the main paper feed unit, and any others that may have become contaminated. Then run the paper feed unit drive belt tensioning procedure outlined in the troubleshooting section of the manual.
        At the same time, make sure you address the cause of the spill (development unit bushings), or you will be doing this all over again.
        Don't take that toner with me!
