Put the .fwu files in the romdata folder.
If you have all the firmware on the SD card, the machine will see firmware ONLY for the options that are installed.
It will list its current level on the left side of the op panel and the SD card level on the right. This will display even if the version is the same or older on the SD card.
To downlod simply highlight the SD card level and follow the indication on the panel.
Check the release notes for System / Copy and Engine and load in the correct order if instructed.
There will probably be more than 1 page of updates, look for an incon on the left(?) to scroll to the next page in the list.
These machinnes are much easier and safer than the older models. I'm sure that once you see the lists on the machine all will become clear. It's difficult to make a mistake as if you have downloaded the wrong firmware it will either not be recognised or will show as older than the version already on the machine. Just allow plenty of time and load one unit at a time and all should be OK.
