Mp5055 Erase all Memory is hidden
  • Marwan
    • Oct 2023
    • 28
    Greetings for all,
    i have returned a MP 5055 from the customer,however i need to Erase all Memory but the ease button is hidden i can't press it,
    is there a Sp mode to solve that ?
  • Codex
    • May 2008
    • 701
    Re: Mp5055 Erase all Memory is hidden
    Hello
    Why you have to erase the memory?... If you mean the personal information you can format the HDD. It's not a good idea to make a "memory clear"
    Inviato dal mio SM-S901B utilizzando Tapatalk
    Memento Audere Semper
      • 37480
      If by hidden you mean greyed out, you need to be logged in to User Tools as the correct administrator.
        • 37480
        Originally posted by Codex
        Hello
        Formatting the HDD through SP mode does not erase the data. It only erases the folder and directory structure. To erase everything. the drive needs to be connected to a computer and a low level format done or use a drive utility that can do a wipe disk function.
        • Elmo
          • Feb 2010
          • 541
          you may have optional software installed
          goto user tools extended features and look if you have you may need to be logged in as admin to uninstall them
          I Used To Live To Fix Things Now i Fix Things To Live
          • sandmanmac
            • 3981
            x2 on this.
            I would just add that you may need to enable administrator authentication first, before you're able to login
            • Saturn
              • Nov 2023
              • 171
              If the optional software is installed as an APP at the SOP, you can uninstall it in SOP Service Mode.
              I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
              • Marwan
                • Oct 2023
                • 28
                thank you sir,this what i'm having,i have logged as administrator and tried supervisor as well,still greyed out
                • Marwan
                  • Oct 2023
                  • 28
                  i have changed the whole HDD same issue,still grayed out
                  • Marwan
                    • Oct 2023
                    • 28
                    i have deleted them all,also i entered the recovery mode and wiped all to the factory reset and still greyed out the Erase on the administrator tools
                    • Marwan
                      • Oct 2023
                      • 28
                      Originally posted by sandmanmac
                      x2 on this.
                      i did sir,still not working
                      • Marwan
                        • Oct 2023
                        • 28
                        yes,i went to recovery mode and wiped to factory rest even the apps on SOP has been deleted but still erase is greyed out
                          • 37480
                          There are multiple Administer accounts (3 or 4) and each can have a different logins and be assigned different access. All supervisor can do is modify the administrators. Make sure the credentials you are using has the needed access and does require a password,
