Mp c4504asp scanning mode
  • Polo-022
    • Sep 2007
    • 484
    I have a scanning mode problem with this machine.
    Scanning from platen glass, the image is shifted too much and a black border
    appears on both sides(Short Edge-Long Edge). When i print the scanned document the top edge is shifted
    to the bottom edge and the lead edge is shifted to the trail edge.
    Scanning from SPDF, single sided or duplex, the image is normal.
    All adjusments from birth certificate and more have been checked.(Default)
    Same problem lately appeared on an MP C3004ASP.
    The only thing i did, till now, is to make adjustmens to move the image up
    and down, left or right (SP 4-010-001 SP 4-011-001)20240309144335434.pdf20240309143041306.pdf
    Any help will be much appreciated! Thanks in advance...
    I forgot to mention that copying from platen glass is perfect, no shift at all.!!
    • 37481
    Re: Mp c4504asp scanning mode
    On many models the scanner speed is different on scanning than for copying. Try scanning at 1200x1200 which I believe is the copying resolution. If that corrects the problem, then there is a timing error between the time the carriage leaves the HP sensor and when scanning actually starts.
    • Polo-022
      • Sep 2007
      • 484
      Image is reduced when scanning to email only
      I found this...
