Please help / installing ricoh mp7502 language
  • baba
    • Mar 2024
    • 4
  • Saturn
    • Nov 2023
    • 171
    Re: Please help / installing ricoh mp7502 language
    Welcome to CTN. First of all, please write in English as this is an English forum.
    If you give me a mail address, I will send you the language firmware. It's about 3.3 MB.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • baba
      • Mar 2024
      • 4
      • Saturn
        • Nov 2023
        • 171
        Please check your mails.
          • 37515
          [quote]
          • baba
            • Mar 2024
            • 4
            I was going to upload files with the 4GB SD Card I had. However, my technician said that if I insert the 4GB SD Card, the machine will not read it and it will cause problems. I wonder if it will cause any problems on my machine if I try it with my 4GB SD Card?
              • 37515
              MP 7502 might require a 2GB SD card. And some of those might not work. Best to use either a 1 GB or 512 MB card. If you don't have and cannot find one to purchase, you can use a utility such as MiniTool Partition Wizard to create a 1GB partition.
              An unrecognized card will not do any damage to the 7502. It will just give an error when it tried to read the card. Power off, remove the card and power back and it will be fine.
              • baba
                • Mar 2024
                • 4
                Slimslob and saturn, thank you very much for your help. 1GB SD cards were not sold anywhere, and by asking photographers one by one where I lived, I found 1 1GB SD card and installed it. I successfully translated my machine to Turkish language. I am grateful to you
