how to change Ricoh 270, Ricoh 1035 Power supply 110 to 220 volt
  • nasrullahbutt
    • 58
    dear any 1 plz tell me how i convert Ricoh 270, Ricoh 1035 Power supply 110 voltage to 220 voltage.
  • TonerMunkeh
    Professional Moron
    • 3865
    Put a 220v power supply in it, new fuser etc. The lamps are different. Easier just to get a 220v machine in the first place.
    Hit it.
    • +ve charge
      • May 2008
      • 87
      Hi... Yr from my part of the world. The easiest thing to do is to use these 110v machines with a step down transformer (which will convert 220v - 110v) and is an external device.
      We had tried this with analog (some years back) and worked successfully. But Digital machines??!! Haven't tried so not sure. Why don't u have a go and let us know
      • Jomama46
        • 2900
        Digital will be even easier as they generally use switching power supplies so the hertz is not as much an issue. The lamps will take a little longer to warm up (if the hertz is lower) so you may have to change them but I have has some success in the past.
        sigpic
        A+; Network +; PDI+
        • imaginemoko
          unTrusted Tech
          • Jan 2008
          • 289
          just place a step down transformer with a more high amperage ratings for more safety.. we already in practice to it a Aficio 1060 110v to a 220v we place a 1500A for its 1250A ratings.
          fix the customer first then fix the machine... its simple and makes life more easy.
          • Matoku
            • 173
            hello ,we are selling the recond machine more then 600 unit wich is 110V. we are using the step down transformer 220-110V/15kva.
            All are no problem. You dont need to change the machine to 220v power supply.to buy transformer is cheeper then to buy power supply, heater unit that all.
            good luck
            • PinevskiS
              • Jul 2009
              • 283
              AAAA
              AAAA
